Weldment Type & Size menus not available
We have just installed SW2008 SP5.0. We have a seperate location we reference for all SW file locations and the weldment profiles folder is set up the same as it is in the SW Data folder:
Weldment Profiles-->
ansi inch or iso-->
subfolders in ea of those w/ c channel, etc-->
then the profiles.
The problem is when structural member is selected we can pick an optioin in the "standard" pull-down menu but the other two menus for "type" and "Size" are unavailable. Has anyone had this problem or know off-hand what may be causing it?
ansi inch or iso-->
then the profiles.
