Ghost images
Ghost images
I have been having a very odd problem that athough does not stop me from using SE, it does make it difficult.
The problem arrises when I am creating features on a part. For example say I have a block that I want to put a threaded hole in. When I am in the hole environment I will clock on the hole command and move it to place. Durring this move the hole leave behind a ghost image of itself everywere it goes. It kind of makes a trail of holes. I will place the hole then resize the view. All I am left with then is the hole, right were I placed it. If I go to add a dimmension the same thing happens. The dimmension value and line leaves a ghost image everywere it goes. I resize, and all I have left is the dimmension, right were I placed it.
Has anyone else had this problem and is there anything I can do about it.
RE: Ghost images
You can always hit F5 to refresh your screen (bad way)
greetings Henk
RE: Ghost images
Try turning down the hardware acceleration on your video card. Right click on the desktop and it's under:
Properties > Advanced > Troubleshooting
Set the slider one tick to the left and check to see if SE is any better. Keep going, one tick at a time, until it's OK. You'll have to start a new session each time you move the slider.
Hope this helps,
Chris
RE: Ghost images
If that helps, its time for new drivers or a new graphics card. But you can run on Backing Store for as long as you can afford. You'll just see a slight delay after rotating or moving objects for the screen to refresh.
--Scott
--Scott
For some pleasure reading, try FAQ731-376
RE: Ghost images
What you are seeing is VERY typical of ATI Rage-128 cards, and even the low-end FireGL series. If you have an ATI graphics adaptor in your machine, I would recommend investigating other options (nVidia Quadro-FX for example).
