Fix a table in a drawing with Solid Edge
Hello everybody. I'm french so I'm very sorry if I make mistakes.
I'm in an alternate engineering school. For my job I have to use a table in a drawing and I want this table be fixed in the bottom right hand corner of the drawing.
I have a problem, when I add a straigh to the table, the table add this straigh from the bottom of the table. I would want that this straigh will be added from the high.
Is it possible ?
I tell you thanks in advance.
Good bye !!!
Is it possible ?
Good bye !!!
RE: Fix a table in a drawing with Solid Edge
Don't apologise, your English is good.
If you mean to have your table go from bottom to top, there is a setting on the 'Sorting' tab of the table properties - 'Reverse order of entries'.
Check this box and the table will grow upwards instead of down.
If you just want to add a row into your table, on the Data tab of the table properties, select the row where you want to add more rows, then click the 'Insert Row' icon (the first on the left hand side) and you can add any number of rows before or after the selected row.
Hope this helps.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
It's her.
Thanks.
You will just have to manually position it.
bc.
Quadro FX4600.
Good election !!!
