Question on Calculating Force on a Roll Pin
I am not sure how to calculate the force due to compressing the spring pin (diameter) into a hole.
Can anyone enlighten me?  Is the Force exerted on the hole simply delta diameter * Spring force?
This is the type of pin I am refering to;
http://www.micromatic.com/images/3/300x300/100-302.jpg
On my spec sheet I see;
JIS B2808-1990
and
Strength Firmness = 70+/-5 (JIS K 6301)
(I don't have any information on this JIS K 6301 specification.  Could anyone enlighten me?)
RE: Question on Calculating Force on a Roll Pin
Downward force = coefficient of static friction X Spring Force
coefficient of static friction for steel to steel is
.15 to .25
Hope this will help you
Ok, Not sure I stated the problem propperly.
The plastic body that the roll pin gets pushed into has a smaller diameter hole then the OD of the Roll pin.
I am trying to see the stress in the plastic eventually.  But to get there, I need to figure out a way to approximate the force the roll pin exerts on the plastic body when it is inserted.
I think the only thing I can measure is an approximate diameter of the spring pin when inserted.  Use this to approximate the force the pastic sees.
I am not sure how to get a "spring force" from the JIS B2808 or Strength rating of 70 (what unit that is?).
For the stress calculation, you could use a press fit equation, but you would need the stiffness of the pin.  Contact the pin manufacturer.
JIS K 6301 is a standard describing mechanical testing methods.  I believe the Strength Firmness is the double shear strength of the pin in kgf/cm2.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks.
