Mixing Steel and Aluminium in sheet plant
Can anybody direct me and name the most important issues that we should take into account when stamping/cutting &welding steel sheet products and aluminum sheet products on the same factory floor?
For instance: are there any measures needed to shield steel chips from our aluminum sheet or vice-versa.. et
thanks
Johan
thanks
Johan
RE: Mixing Steel and Aluminium in sheet plant
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
