Arc vs. Chamfered Wiring?
I am trying to learn some basics about wiring.  I found a reference to Arc Wiring in book but there was no explaination as to what Arc wiring is.  There was also a reference to Chamfered Wiring but again no explaination.  What are these?  Does anyone know of a good website that describes these wiring types?  Thanks.
RE: Arc vs. Chamfered Wiring?
Huh?
Could you perhaps reveal which book?
Mike Halloran
Pembroke Pines, FL, USA
It is terminology relating to CAD layouts of wiring used in construction rather than physical installation methods. Have a look at http://augiru.augi.com/content/library/au07/data/paper/ME500-1.pdf, particularly page 30 of 41
Oh, and check out www.google.com: that's where the answer above turned up. surprise
Is it a very, very old book that dates back to the days of arc lights and wood strips to conceal wiring?
Bill
"Why not the best?"
Jimmy Carter
This has nothing to do with electrical wiring, but how to draw it in acad.  An arc takes points and draws a part of a circle.  A Chamfered is a way of rounding a corner in a drawing, you select the radius of the corner so it looks rounder.  This is ways that acad draws a wire.
Sorry guys... I found this in some RevitMEP literature from Autodesk.  Got these terms mixed up with notes from other references.  pwrengrds - I think this is what they are refering to - simply a different way of formating linework on electrical drawings.     Thanks for all the responses!
Oh ScottyUK, thanks for the insight into www.google.com... never heard of that before winky smile
Hi scottbaldy, t'was meant in jest. lol
Is this terminology unique to that software package or is it used throughout the industry? I don't do much building services work so I'm curious.
