What is COF for level transmitter?
I have provided the datasheets for selecting the level transmitters for some vessels. These level transimitters will be installed either on the top nozzels or on the bridles of the vessels. I have included the Normal, L, LL, Hi, Hi-Hi ligquid level information. The vessel overall dimensions are also shown.
But the problem is that the user wants to get the COF (center of float?) information for these level transmitters. What is the exact definition of COF? What is the purpose/reason of using this number? Is it really necessary to have it in order to select the correct level transmitter?
Thank you in advance for your help.
RE: What is COF for level transmitter?
If it's a top mounted Magneto-restrictive type it wold have a float, perhaps they are trying to figure out how much of the float is immersed.
Or perhaps they don't know what they are talking about.
Roy
Level switches have a center position with markings for the high level and low level switching points. Depending upon the manufacturer, the marks could be the actual switching point for the minimum specific gravity of that model; or perhaps for water. See the vendor data to assure that this is understood. For mixed hydrocarbons, the marks are not likely the actual switch points for the fluid.
