Expediting a Wet Well Lining
We are currently under contract for a project in which we would like to incorporate an epoxy coating, for protection of a wet well. The wet well itself will be precast and the epoxy coating, according to the specifications, should be applied 28 days after casting.
I am aware of the Sikagard 75 product, which provides a special epoxy/cement combination mortar to allow application of the protective lining. However, this product seems too costly for application, as someone would literally be in the manhole troweling this stuff.
Does anyone know a means of mitigating this circumstance, allowing for a more immediate application of the epoxy coating? Perhaps some sort of spray on material?
Tom
Tom
RE: Expediting a Wet Well Lining
The second URL is some washing equipment I've seen used for cleaning manholes and sumps.
http
htt
