Circular Instance in NX4
Does anybody know how to do a circular instance of a sweep in NX 4?
I have created a funnel shaped hole using the sweep command, then subtracting it from my solid.  I would then like to instance (pattern) about the axis of my part.  However, when I start the instance command, the solid part I have made is not an option to select.
Have I done something wrong?
What should I do to get this to work?
RE: Circular Instance in NX4
Make sure you are using Insert>Associative Copy>Instance Geometry rather than Insert>Associative Copy>Instance Feature
Instance Geometry was not available in NX 4 as it was a new function for NX 5.  Try creating a Feature Group even if it contains only a single body and then see if you can instance it.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Using a  feature group worked....thanks John
The other often used alternative is pattern face which would be available if the body is united to another solid. It seems to be a little neater and cleaner in the tree and does not appear to so severely drain system resources to process addition boolean operations.
The beauty of creating a feature group as the input to an array pre-NX-5 was that it will allow the array to exist without a prior boolean. Of course if you do have to later perform multiple booleans those may be slower to process.
Cheers
Hudson
