Circuit Breakers Used as Switches
Can a larger circuit breaker be used as a switch on a fused circuit sized for a lower current?
i.e. a 70A breaker used as a switch on a circuit fused and sized for 40A
RE: Circuit Breakers Used as Switches
I await enlightenment from one our "code lawyers".
A Molded Case Circuit Breaker (MCCB) would need to be labeled "SWD" for switching duty I believe, but as far as I know, almost all new MCCBs are now labeled as such. But the term "circuit breaker" is a little nebulous now with the advent of what are called "Mini Circuit Breakers" or MCB from IEC countries. I do not believe they are going to be labeled to be used as switches.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Keith Cress
