corrugated flex vs expansion joint
I am tring to spec some turbo outlet exhaust connectors and was wondering if someone could tell me the difference between a corrugated flex joint and an expansion joint.
RE: corrugated flex vs expansion joint
A corrugated flex joint is a type of expansion joint.
Exhaust flex joints for turbo engines are usually a stainless bellows (to provide the flexure) with a stainless over-braid (to keep the bellows from blowing out):
http://www.seniorflexonics.com/#m3/pg1/p05-01
Good luck.
ISZ
