ISO 9000 Auditor Training Courses
After a brief web search, it appears there are many courses offered.  Can anyone make a recommendation as to a training course(s) offered in the US that will lead to accreditation as an auditor?
RE: ISO 9000 Auditor Training Courses
More information is needed.
What does your company do?
Are you talking about ISO 9001:2008 Internal Auditors?
Where are you located geographically?
Etc, etc.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
MM,
The vessel manufacturing company I work for is located in Texas.  Yes to your second question.
I mislead you a bit, as the 2008 version of ISO-9001 is not official yet, so you will be training under ISO-9001:2000. If no one is familar with ISO-9001, some up front research would be recommended. http://www.praxiom.com/iso-9001.htm
You should look into Lead and Internal Auditor training, probably include an executive overview course for the bosses.  I would start by finding a Registrar in your area, they will be able to direct you to recommended trainers.
ASQ has training on ISO.
I believe they conduct training & test twice a year.  There are different regions that schedule differnt times of the year.
