Angular Dim text & line position
In Draft mode:
I could not able to position angular dimension text where I wanted to. SE is restricting text position. Attached file explains it more.
Do anybody have solution?
RE: Angular Dim text & line position
RMB on the dimension then Properties.
Now on the Lines and Co-ordinate tab set the Break Line Gap to a NEGATIVE number.
So if normally it's 1.5 set it to -1.5
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
bc.
Quadro FX4600.
It is not working either way. There is no "break line gap"
I have tried following.
Under Dimension Line
stack pitch: -1, -1.5 and other values
Break Line: (negative not allowed)
Under Projection Line
Element Gap: -1, -1.5 and other values
Extension: -1, -1.5 and other values
Break: (negative not allowed)
bc.
Quadro FX4600.
My solution works on V19.
bc.
Quadro FX4600.
There is quite a simple method of moving the dimension value and that is to first click and hold the number with LMB, then press and hold the shift key. You will then be able to move the location of the dimension value.
M
This works. Simple but very useful solution.
Any more instances where that solution works?
bc.
Quadro FX4600.
