insulation
insulation
If i cut a hole in the metal covering of tank insulation to do some ultrasonic testing, what is a good way to seal it until the next round of testing? these are outside tanks
RE: insulation
What type of insulation? Aluminium cladding? What's behind the aluminium? How good of a seal do you require? Is the exterior of the tank primed?
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
RE: insulation
-handleman, CSWP (The new, easy test)
RE: insulation
RE: insulation
proof, save making another hole, etc. Studweld is one of several manufacturers.
http://www.studweld.com/plugflng.html
RE: insulation
http://www.ndtseals.com/
