Imperial Hole Table
Imperial Hole Table
Imperial Hole Table
I'm Running V5 R17. I have my drawing template setup to imperial. All dimensions work fine until I create a Coordinate Dim or a Coordinate Hole Table. Then, the it generates a Metric Hole table. Anyone know how to convert the table into imperial?
http://mtm-cadtutorials.blogspot.com/
RE: Imperial Hole Table
Check your Drafting Standards an make sure the Tables are set to the correct Dimension Style
