Ideas on this Connection
I am designing this connection
http://img88.imageshack.us/img88/3904/beams1fz2.th.png
Im using Descon, but it only can design the connection for the main plane.  But i also have two braces comming into the joint in another plane. Any ideas on how i can get these connected to the joint?
RE: Ideas on this Connection
With a bracket?
Gusset plates.  Are you designing the connection, or is a computer program doing it?  If you rely solely on a program, no need to come looking for assistance when the program doesn't work.  You need to understand the design yourself.
Well, i am having the computer to design the general layout.  Then I am going to design the connection and welding.   Every book i have been reading about welding only talks about simple connections.
Where can i go to research advanced connections where 7, 8 members coming to a single point?
Try looking at some of the API offshore specs.
Where can i find these?
See if you can do a search on space frame connections.
try Troitsky's "Tubular Steel Structures" & AWS D1.1 for "K" joints
