Motor Switchgear undersized for motor
We have an application where an owner wants to use a 250HP motor to drive a cooling tower fan but he wants to keep his current switchgear that was rated for a 200HP motor.
We can pitch the fan so that it does not require more then 200hp from the motor but is this going to work?
RE: Motor Switchgear undersized for motor
If you don't need a 250 hp motor, put in something smaller. I
& thanks for all your comments.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
But on a ratio of 250 HP to 200 HP it will probably work. Just the same, I don't want to be in either the electrical room or near the motor if the contactor opens under starting current. But that's just me.
Bill
"Why not the best?"
Jimmy Carter
