Field with DIESEL expression does not update
Basically I want a mtext field that is linked to a attribute in an object.
Easy enough, you just take Edit Field -> Objects -> Object and select the object and the attribute you want.
The field formula looked something like this: %<\AcObjProp Object(%<\_ObjId 2130252728>%).TextString>%
Then I realized I only want part of that attribute so I used a DIESEL expression looking like this: $(substr,Hi,2) and replaced the word "Hi" with the field code. The result looked like this: $(substr,%<\AcObjProp Object(%<\_ObjId 2130252728>%).TextString>%,4)
Problem is now the field doesn't update when typing REGEN and it doesn't update when typing UPDATEFIELD. Tried with booth FIELDEVAL=16 and FIELDEVAL=31.
If I doubleklick it, right click and choose Update Field it will update but if you have a large number of fields it's no fun to use three clicks on each to update them. The whole idea with fields is kind of lost...
Any ideas about this?
RE: Field with DIESEL expression does not update
CarlB: I assume that you mean "fields without diesel expressions". The answer is yes, fields without DIESEL expressions update on REGEN and when saving etc. (according to the FIELDEVAL variable I assume).
