Open Channel Flow
Open Channel Flow
I am working on calculating flow from tides in and out of a salt water pond. There are 2 possible channels for the flow to enter and exit. I know roughly the rise and drop of the pond from high tide to low tide to be about 6 feet and I know that the pond is 147 acres. I have calculated flow rate by being the volume of the water exiting in a tide cycle divided by the 6 hours it takes for the tide to drop. However from fluids I know that there are a lot of losses from funneling all of this water through 2 small channels. Any advice or recommendtions for literature I could look at?
RE: Open Channel Flow
http://vtchl.uiuc.edu/
The following texts are recommended reading for those interested in learning the fundamentals of hydraulic analysis:
Chaudhry, M. H. 1993. Open-channel flow. Prentice Hall, Inc., New Jersey. 483 p.
Chow, V. T. 1959. Open-channel hydraulics. McGraw-Hill Inc., New York. 680 p.
Henderson, F. M. 1966. Open Channel Flow. MacMillan Publishing Oc., Inc., New York. 522 p.
