Structural engineering - green roofs
Can any one please tell me what loads should take in KN/m2 for a saturated  extensive type of green roof having a depth between 75-100mm.
RE: Structural engineering - green roofs
I would say 2 kPa per 100 mm for the saturated soil load.  But the "green roof" installer should be able to give you a better number.
Look for information from a few different manufacturers.  They usually provide this.
2.4 KPa is about 50psf.  This is a growing green roof load of short bush/tall grass height.
Try the following reference if you can get hold of a copy
http://www.ribabookshops.com/site/viewtitle.asp?sid=&pid=8843&HID=
which should take you to
Planting Green Roofs and Living Walls
Revised and updated edition
Authors: Nigel Dunnett and Noel Kingsbury
regards HM
No more things should be presumed to exist than are absolutely necessary - William of Occam
