Hot Surface Warning
Hot Surface Warning
I would like to ask what is the threshold surface temperature of electrical devices from which the application of "HOT SURFACE" warning sticker is mandatory and which standard(s) could be applied ?
RE: Hot Surface Warning
It is likely defined in a standard applicable to wherever you are - without that information it's difficult to help.
Basically, I would like to know when is the usage of the following sign type mandatory : http://www
As a general rule of thumb, we put the warning label on any equipment that may reach above above 60 degC. VFD heatsinks for instance.
Matt
Suggest you try NIMA website for details -National Insulation Manufacturers Association.
Also, temperatures over 80o Centigrade can cause 2nd degree burns (definition of arcflash protection boundary to limit burns to a curable 2nd degree burn, temp >80o)
Hope this helps
I have found at the OSHA discussion http://www.eng-tips.com/viewthread.cfm?qid=79451 that the suggested limit should be around 140F ( 60 C ).
