Law curve define
Law curve define
Hello
I'm trying to make a law curve for define the evolvent of an gear teeth.
I define the x,y and z equations for the spline and a constant that define from where the curve starts.
Now, I'm having trouble to define the law curve paramteres.
Tadej
Tadej
RE: Law curve define
Law curves are both powerful and (potentially) complex. The above is one way to use them; there are other ways to create a law curve, e.g. based on another curve or a simple linear progression.
Perhaps if you post what you have so far we can all put our heads together and come up with something both usable and robust.
Ok...now i don't need any help...but when I finish to make the gear with spline feature...I'll post the model, so you can see how things works....
It would be a parametrized feature that do any type of gears with evolvente. If anybody will need that.
Tadej
