check valve on end of pump outlet
I was hoping i could get some help on placing a twin plated wafer check valve on the end of a pump rated at 300m3/h. The pipe diameter is 200 mm, 8". I've tried to obtain as many data sheets with CV numbers etc,
I want to calculate the pressure head losses. The valve is ideally placed 5 to 10 diameters away from the discharge end of the pump but it will be a lot less than that.
Any alteratives would be great along with ideas.
Many Thanks
BML Engineer
Many Thanks
BML Engineer
RE: check valve on end of pump outlet
Offshore Engineering&Design
"If stupidity got us into this mess, then why can't it get us out?" - Will Rogers (1879-1935) ***************
http://virtualpipeline.spaces.live.com/
