Generator Inspection
I'm trying to see what are the best procedures to test a generator and recently it came to my knowledge a machine in the spanish market that cough my attention. it is called EDAIII from unitronics.
http://www.unitronics-electric.com/EDA.html
Check also the attachment, for me, it seems interesting,  until the part where they say in page 9 "When EDA test gives evidences of one or more insulation problem, it's the time to confirm this issue with 2nd instance techniques".
The advantages seems to be that the machine can be operated by a non-expert guy and if evidences problems are found then it should be used other techniques.
If you guys have time, give it a look and give me your opinion.
By the way does any one have a gook book about generator inspection/maintenance?
Thanks and regards,
