"Stiff" Source verses a "Weak" Source
On a similar note to a previous posting regarding faults and short-circuits another question was discussed regarding what constitutes a "stiff" source of fault current. Again opinions and thoughts were divided as were the responses.
Some defined a 'stiff" source in terms of bus voltage and ratio of short-circuit to load current with a ratio greater than 5 being considered a stiff source. While others preferred to define the "stiffness" of the source in terms of source impedance.
I would be interested in others opinion on this subject and how they would qualitatively define what they consider to be a "stiff" source of fault current. Thanks for your input.
RE: "Stiff" Source verses a "Weak" Source
Stiff systems (high short-circuit current in relation to load current) can absorb higher harmonic currents without causing harmful harmonic voltages.
