Stress change with mesh density.
Hi, I'm trying to become a bit familiar with ansys workbench before my employer sends me off to a course. (a slow process)
I have a straight pipe section that I simply want to pressurize from the inside.
I use a cylindrical support on the outer surface with Radial set too free and Axial and Tangential set to Fixed.
Algorithm is patch conforming, method: tetrahedrons.
When I set the mesh from Course to Fine, the Equivalent Stress readings go up pretty drastically. I think this is telling me that there is something wrong..
Are there some simple things I need to do so this doesn't happen?
Thank you for your patience on this boring question :)
RE: Stress change with mesh density.
The mesh density does effect the final results. In general, a finer mesh results in more accurate stresses. But its gets to the point that refining the mesh further would significantly increase the analysis solve time and not produce a meaningful difference in the final result.
