power supply manufacturer
I'm kind of new to the electrical engineering field (particularly electrical components, etc.)  Who would be a good supplier for a dual output power supply?  I am not having much luck with an internet search.  I need a plug in for 120 VAC and a 5V and -5V outputs.
Thank you in advance for your help!
RE: power supply manufacturer
I sounded like he wasn't looking for a bench supply.  But I look there too.  Newark is always about 5% more $$ and I had a nasty run in with them once.
  They sent the wrong parts.  They were $100 IC amplifiers, six of them.  I opened the box and saw they were the wrong part. Some dash number option.  They refused to take them back since the box was opened even though I never even touched them.
I was never going to take no for an answer, so they finally took them back after weeks of increasingly heated discussions farther and farther up their chain of command.  They are not my favorite vendor.  :)
Keith Cress
Thank you for the help I think I've got one found through Digi-key
