Fyrquel Change-Out
Fyrquel Change-Out
All,
We are looking at replacing our bearing oil, Fyrquel, with a Mobil DTE 797 or 832 and would like to know if there are any major pre-cautions that we should consider.
RE: Fyrquel Change-Out
I know lube oil contaminates Fyrquel and cause problems when passing throught servo valves, but have never heard of lube oil having problems with a little fyrquil in it.
I would gues the big thing would be material compatablity. if it is ground use fyrquil, viton works with either. note aviation fyqruil is completely different
