App. D. - Interaction with Vx AND Vy??
The whole of Appendix D in ACI 318-05, indicates capacities for multiple failure modes in tension (φNn and φVn).
They even offer an interaction equation when you have both tension and shear.
Fine.
But what would be the proper calculation to use if you had shear in two directions (Vux and Vuy)?
Do you calculate a φVnx and then a φVny and then add this to the interaction equation D-31?
In other words:
As ACI published it:
Nua / φNn + Vua / φVn < 1.2
As I would suggest:
Nua / φNn + Vuax / φVnx + Vuay / φVny < 1.2
Does this make sense? ACI says nothing about x and y shear - it seems to assume that you will only have one shear direction.
Fine.
In other words:
As I would suggest:
RE: App. D. - Interaction with Vx AND Vy??
The problem with a vector is that the φVn values are based on ca1 anchor-to-edge distances that are determined from the anchor in the direction of the force - If you use a vector at some angle you have no true ca1 to use.
No examples I've seen deal with this - all very simple (typical academia examples).
You need to check the component in the x direction and the y direction and take the minimum of the two.
Please see the attached file on page 38 and 39 for a description of this.
http:/
Not for the link, but for your choice of team! :)
And my uncle once tried out for the Packers as a kicker - new one of their coaches real well - and knew Ray Nitschke and Donny Anderson....so it's in my family to be a packer - but just wasn't to be.
Long time ago - sitting on my grandpa's lap watching football (age 5 or 6 maybe) and seeing football with black-and-white TV - I thought all the teams were the "black shirt" guys and the "white shirt" guys - both with white pants. Only two teams in the universe as I understood it.
I then one day saw a team with black pants, white shirts, and black helmets. They looked sooo cool. I asked my grandpa - "Who are they?". He answered, "That's the Minnesota Vikings." I answered, "That's my favorite team."
I've been a fan (slave) ever since.
It's been fun watching the two teams over the last decade or so.
Used to be the Bears were the worst nemesis of the packers.. but they were so bad that the rivalry between the Vikings and Packers heated up more than ever.. Those were actually fun games to watch.. records never really meant anything (and still don't).. they just go at it like playground kids...
M = wL^2 / 8 (token engineering content)
