Far Infrared Source Needed
I need a 10 micron infrared source for some pyroelectric detector testing. Prefer a fairly low-cost approach.   I used an incandescent lamp with the glass bulb removed.  The driving circuit was a constant current source.  This worked - for a week - until the tungsten filament fused.
RE: Far Infrared Source Needed
Nernst lamp is one possibility.  It's basically a power resistor.
Another choice is a toaster oven or even a room heater.
TTFN
