Anchor Bolts in Drilled Piers
Why is there no allowance for the shearing of ties in the concrete breakout strength, in App. D?  If you have a pier or pedastal with shear ties, don't the ties have to shear first before the concrete breaks out.
RE: Anchor Bolts in Drilled Piers
The analysis of most of Appendix D assumes concrete only,  reinforcement can be used if the concrete fails.  See D.6.2.9.
In ACI 05 it only goes to D.6.2.7
