problem with user subroutine
I'm using abaqus 6.7, I'm new with it and it's my first simulation.
I'm using a  user subroutine in fortran in order to use a load case and the problem may come from there.
The simulation crash and this is what's in the log file:
LINK: extra operand `/subsystem:console'
Try `LINK --help' for more information.
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
  This error may be due to a mismatch in the Abaqus user subroutine
arguments.
  These arguments sometimes change from release to release, so user
subroutines
  used with a previous version of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors"
Any idea of what is the problem, what is the use of "subsystem:console"
thanks in advance
Kevin
RE: problem with user subroutine
Kevin, are you using an old User Subroutine? According to the message, it looks like your subroutine may have an incorrect number of arguments; inconsistent with the V6.7 subroutine. Check the arguments in the routine you are using against what the v6.7 manual says.
I don't know what `/subsystem:console' is.
I don't remember the "subsystem:console" part but I got this error whenever there was even a syntax error in my subroutine. So it may not be that the subroutine is old and things have changed, it may just be an error in the fortran code.
HTH
