when speedpak no render?
Since a while I have been using SW2009.
Preformance really got better. (even on a octa core xeon)
There is one thing that I can not find out. If I use speedpak, I can not render the part (the part is left out)
Is that normal? I can not find it in the manual.
Erik
RE: when speedpak no render?
That seems to make sense. The part is only there as a graphical representation and not loaded into memory. Just my $.02
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Thanks, but what is the advatage of speedpak.
Since there is no way to easely switch speedpak off again.
I would be great to make an assembly with speedpak and afterwards turn speedpak off, and then render.
But is this possible?
Erik
I believe you can RMB on the part(s) and choose load. I'm not running '09 yet, just going off of my (limited) memory of what I saw at a rollout.
