boiler circulation pump
hi all
pls help me to understand this.
in power plant, why do we need to put a boiler circulation pump to boiler ? what is the use of it? boiler produce steam @ 200deg (c), h= 700m, Q = 50cu.m/hr.
thanks
thanks
RE: boiler circulation pump
"If stupidity got us into this mess, then why can't it get us out?" - Will Rogers (1879-1935) ***************
http://virtualpipeline.spaces.live.com/
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
sometimes certain portions of tubing suffer from overheating - hence need to add "circulation pump"
Critical boilers ( where SG of steam vs. S.G. of water is similar) need to use this pump(s) to circulate water/steam mixture through the boiler( not your case).
