CosmosFloWorks 05 and lofting
I am looking for some tips regarding configuring a hollow tube that has a number lofts for use in Floworks 05. No matter how I configure the "Lids/caps" for each end I always run into the dreaded error that the object does not exist in the fluid boundry when creating boundry conditions.
At first I figured this was due to the feature having an odd inlet that was not 'normal' to the incoming air. So I built a flange and I still had problems.
Any help is appreciated.
