Dry Well Size Calculation
We need to construct a dry well in a poorly graded sandy soil (SM), the Mechanical Engineers discharge calculation is 101559 liters/15minutes, what we require is the formula for calculating the size of and depth of dry well required.
any help will be greatly appreciated, the building in question is a large recreational facility
RE: Dry Well Size Calculation
Around here, drywells are designed with an allowable 36-hour period for disposal. A maximum disposal rate of 0.1 cubic feet per second (cfs) is often used for estimating the number of drywells required.
The harder part is getting good data to plug into them.
Here's a source for formulas:
AN APPROACH FOR ESTIMATING INFILTRATION
RATES FOR STORMWATER INFILTRATION DRY
WELLS
http:
