Air operated valve vs. air operated check valve
Hi all,
I've a question about which device, an air operated check valve or an air operated valve, would be more suitable for trapping air in a cyclinder. Currently, the cylinder is controlled by a 3 position valve, but we want to take extra measures that will keep the air trapped in the cylinder.
Regardless of what device is used, I plan to add another 3 position valve thats connected to a different output of the controller to actuate the air trapping device.
Any information is appreciated.
RE: Air operated valve vs. air operated check valve
-handleman, CSWP (The new, easy test)
