DirectLogic 5 PLC issue
All,
I have a DL5 Series PLC from Automation direct and I am trying to do a simple motor seal in.  I am paralleling the motor contact as a NO contact around the pushbutton input that is triggering the motor to run.  For some reason this doesn't seem to seal the motor in.  Any thoughts?
Rich....
Richard Nornhold, PE
RE: DirectLogic 5 PLC issue
Got a drawing?
A couple things come to mind, off hand;
1) Your sealin bit is being used elsewhere too.
2) You're jumping out of the Stage, and resetting it.
Ed
