How to starting V5R18 in Admin mode?
I need to start V5R18 in Admin mode in order to change/lock some options required by customer. I don't have documentation available and was hoping someone here could give instructions as to how it's done. Thanks for your help.
RE: How to starting V5R18 in Admin mode?
Copy the start icon and right click on the new start icon and chose properties, in the shortcut tab add -admin in the target field.
Think it works also from the command prompt, standing in the installing path ...\Program Files\Dassault Systemes\B1X\intel_a\code\bin
Run: cnext -env  "your enviroment path" -admin
Thanks again for the help. Sorry about the poor grammar in the title thread, too.
Before you start in admin mode you need to edit the CATEnv file to add directories for:
CATReferenceSettingPath=
CATCollectionStandard=
If you do not specify these directories, you will not be able to start V5 in -admin mode.
