Bednar Pressure Vessel Calculations
Hi folks,
I am just trying to assess a calculation for a vertical support foot on a shell and tube heat exchanger. The stress by design calculations were performed using the Bednar method.
Unfortunately, the Bednar pressure vessel design book has gone missing in our office and I cannot check the nomenclature of the calculation with the mechanical design drawing for the support feet.
Would anyone be able to supply me with a picture of the foot in Bednars book or possibly direct me to a website where I might find the same.
Your helps is as always appreciated
RE: Bednar Pressure Vessel Calculations
..The Bednar method is based on WRC 107 and 297
So if you have these or if you have PVelite or Compress, etc.you cando it
