TC-NX5 assebly problem
Hello!
I am working in NX trough TC 2007. When I make an assembly and loud in it some parts from TC that aren't mine(I'm not the owner). Than when I try to save the assembly, the following warning apear (Save warning->No attempt made to save the following parts, as they are read-only. if write access to any of these parts has been granted from PDM, use Tools->Teamcenter Integration->Lock/Unlock Parts-> Refresh locks Status to refresh (and below showing the part(s) that I load in the assebmly).
I not sure, but I'm thinking that in TC the rights of groups or users maybe aren't well defined.
If somebody know this error(warning), I appreciate the explenation.
Tadej P.
Tadej P.
RE: TC-NX5 assebly problem
I have found that teamcentre is better is the better to use if you set up workflow to manage the ownership of files etc.
Cheers
Hudson
thank you, for your advice...
tadej
