What is 'Method Spec'?
I am being considered for a position as a soil tech for a large grading project. I'm required to have knowledge of 'method spec'. Can anyone explain this to me? Your respnses are much appreciated.
I have spent a few years in a geotechnical lab running max-density curves and such, so I have a have a broad understanding of the industry, but limited field experience.
RE: What is 'Method Spec'?
"Construction of Fills" by Edward J Monahan published by Wiley is a good, short book that will give you some insight to the field side
Good luck.
