importing PLOT3D files
Anyone know how to import PLOT3D format files into NASTRAN?
Thanks.
RE: importing PLOT3D files
Would you import the plot3d into Nastran or Patran?
what the source of plot3d file?
Why you need to import it into Nastran?
 could you explain a bit more please?
regards
Hi Onda,
Thanks for the reply!
My end goal is to get the files into the SC/Tetra CFD package. It doesn't take Plot3d files directly, but it does take Nastran format (also takes Universal, Abaqus, STL, DXF formats). So using Nastran (/Patran) as a go-between looked like a possible solution.
The files are Plot3d mesh (grid) files that we got from a business contact. We'd like to set up SC/Tetra models using them.
Thanks again,
- David
The only way I found to do the translation is using ICEM CFD, could read a plot3D file and write a nastran deck file or what other you need.
I'm sorry but I couldn't be of more help
Thanks for the suggestion! I'll see if I can get access to ICEM.
