Maximum stress values...
Hi All
I've got a question about maximum plotting maximum stress values. For example..
I've got analysis that lasts about 10 [s]. A. I want to make a plot of mximum stress values time-dependent. You must known that each inrement of analysis contains different stress values at different areas of a model.
Thanks for help
Thanks for help
RE: Maximum stress values...
Probably not a elegant solution. But can work, especially if the model is small.
Get the stress value of all the nodes for the complete time [10s] as XY Data.
Operate on these XY Data and use the Max Envelope Function. The resulting curve is the plot of Maximum Stress over time.
Guru
www.abaqusguru.blogspot.com
Yes, this is a soulution...but for a small models.
I think that python script may help me with my problem. Surrnetly I try to postprocess results using Ensight This software gives possibility to plot maximum stress values (time dependent) curve.
Regards and thanks for help
Noirom
