Trouble with FACET reference set
I have not used FACET/Lightweight reference sets, but would like to. My customer defaults, assy, site std, is setup with the FACET lightweight reference set. New components are added automaticly.
I have a large component in my assembly, when I set the FACET reference set, only the sheets in the component are visible. I don't get a facet body for the main solid. The component is part of the moldwizard library and goes back quite a few versions I think, the sheets I see are newer geometry that I added.
I've searched the help files, but they suggest this should be an automatic process.
NX 5.0.3.2 MoldWizard
RE: Trouble with FACET reference set
Cheers
Hudson
