unfold / flatten sheet metal tube
I have a sheet metal tube with a circular cut on one end.
such as if you inserted a 3" tube into a 6" tube at an angle of 30 degrees. Off the axis of the 6" pipe. so now the 3" pipe has a cut that follows the profile of the 6" pipe. A typical y intersection.
I now want to take that 3" pipe and unfold it to make a simple tracing pattern. It is currently a sheet metal part.
when i unfold it, the program errors out because it cannot deal with the bevel from the cut.
any ideas or another approach??
Gary
Gary
RE: unfold / flatten sheet metal tube
I was looking for a way to develop that square face, haven't got there yet..
thread559-154225: Flatten a pipe
FAQ559-807: How can I flatten a curved surface?
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
The hard way to do this would be to copy the OD surface (using offset), trim the surface, then cut using thicken.
