loft question - intersect guide curves with plane
Got a problem: I am lofting a nose cone, which has a non-circular cross section. I have 4 guide curves, and I need to make an additional cross section between the base and the tip. But when I try to create points by intersecting an intermediate plane with the guide curves, I get a message: "failed to create reference point"
I need to intersect these guide curves to create the cross section. What am I missing here?
Thanks in advance,
boffin5
Thanks in advance,
boffin5
RE: loft question - intersect guide curves with plane
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Another question: I know how to move a body (surface) with the move/copy tool, but is there a way to do the same thing with curves? There has to be!
boffin5
