Wind Loading on Camouflage Netting
Does anybody know of any tests that have determined the coefficient of drag for camouflage netting?
The only way I can think of making an assessment is to break it down into two parts:
1 - The part of the camouflage that remains perpendicular to the wind at all times. I could assess the drag for of the core fabric netting, something like a chain fence.
2 - The Part of the camouflage that flaps in the wind. I could calculate the drag on a lot of 'little flags'
I could then add these two parts together.
Any better ideas would be helpful.
RE: Wind Loading on Camouflage Netting
If you have netting, you could get anything in the net and throw all your calculations out the window. When you get wind, you get debris that could be cumulative. Just a ream of paper could double your wind loads.
If you are concerned about the structural support, base your design on the strength the netting can conduct to the structure or what the supplier can provide based on the real conditions it can encounter. A good supplier can tell you the performance of the netting they supply.
If you have a big wind, it will be cheaper to replace the netting than rebuild the supports since the netting will fail first.
Dick
If can get with your supplier and get his mesh breaking strength values an as stated above and you can design your supports for this value if laced to a strand or if tied off use the breaking strength of the tie rope. As noted above one would normally want the net proper or the ties to fail before the supports.
Any manufacturer should be able to give you the thread and mesh sizes along with the single strand and mesh breaking strengths. If you are lucky they may have some wind resistance numbers.
We are looking at wrapping a 30 storey building in camouflage as it is being constructed, then when the building is near completion it will be unveiled. It's just a big publicity stunt, but should be a bit of fun!
I just assume that the netting is solid. And the breaking strength really does not give you a good idea of when or at what wind speed it will fail. That has a lot to do with the "sag" of the material and how it was installed. Larger sag - higher wind speed. The old suspension bridge cable problem.
One company extolls the virtues of their shrinkwrap by stating it will withstand a 125 mph wind - and it did - damn near wrecking (wrecked some of it) the scaffold on which it was installed.
Monarflex uses small "bungee" cord type attachments that have predictable blowout loads based on the number and type of installation.
Good Luck
