Graphic Methods for Sag-Tension Calculations
Does anyone know where I can find a copy of Alcoa's "Graphic Methods for Sag-Tension Calculations" that was published in the 1960's?
I have an original of the 1927 version, but am interested in creep which that version does not address.
Thank you!
RE: Graphic Methods for Sag-Tension Calculations
Try the Linda hall Library. They have an icredible selection of engineering documents. They are on line at
www.lindahall.org
Thank you.  I was able to find what appears to be that document as part of a larger ALCOA document and requested it.
The document is "missing" from the Linda Hall Library.  Does anyone know of any other sources for this document?  I have been unable to find any online.
I'm interested in Alcoa's "Graphic Methods for Sag-Tension Calculations" that was published in the 1960's but i can't fint too.
I don'thave the original of the 1927 version, where i can found it?.
Thank you!
I "inherited" it from the person who held my job before me.  It looks like the University of Wisconsin-Madison library system has a copy that you could possibly get through inter-library loan: http://www.worldcat.org/oclc/55694641
