Running command lines to heat transfer analyses
Dear all, I have some trouble with the command line. I have a job called  job0025.odb. What I want to make is to trying to get nodals temperature information from 96373 nodes . Moreover,I wrote the inp-file previously with this
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*El Print, freq=999999
*Node Print,Nset=BALL, freq=1
NT11
*End Step
Then I am starting to run my job in a command line like this
c:\temp>abq64pr11
identifier:   (appears)
(do i have to write the variable:NT11 or job0025??)
 Because If I choose job0025 inmediatly appears
inp file                :  i write job0025
but never call for a rerun the job0025
could you please help me?? I think something is wrong with this.
thanks in advanced
love
Paulis
